eluminator
Radio Shack sells a "low intensity" diffused 3 mm red LED that I use as an indicator light on the pc boards I build. I like it because it is more than bright enough when using 0.5 ma.
I haven't been able to find any others that come close to it's efficiency. I've tried various "high efficiency" 3 mm LED's from Digikey but they require at least 5 times the current to be as bright.
The part number is 276-026. I notice three other differences between this and my other red LED's. The epoxy case is tinted a lighter red, the case is a bit longer, and the peak wavelength is 700 nm.
This part number is shown on RS web site but the description of the LED on the web site is different from what's on the package.
Anyone know of another source for a LED like this? Anyone know if such an efficient LED is available in other colors?
