Who make the brightest light with....
Doug
SoCal
Who make the brightest light with with a simple interface, some sort of blinking light so you can find the light when it is turned off, very dim mode, moon light mode, like 1 lumen, and can be charged by USB? 5,000k prerably, and flood. Any suggestions? Thanks!
CelticCross74
Fairfax Va
first light that pops into my head is the NW Nitecore MH20. Its USB rechargeable, 5000k, has the low modes although they have tested out here to actually be higher than spec YMMV. I think the side switch has a location function Im sure more will chime in on that part. Its two stage switch, like the shutter button on a camera, in my opinion is pretty easy to use. I should know the location function part Ive got all 3 MH20's hmmm. The NW MH20 has a very well done wider than average beam profile. Its a great XML2 beam with a slightly larger than average hot spot, visible and even corona and lots of bright spill.
