Hi all, I am putting together my first p60 light. I am using a drop in that has a recommended input voltage of 4.2 to 8.4 volts. I believe you want to run the minimum voltage possible to keep excess heat down but I am right on the upper edge of single 18650 voltage so I want to see if you think I should run a single or a double.
Thanks for for your help
