c0pperheaded
- Joined
- Oct 18, 2016
- Messages
- 5
I have a Fenix e01 and I love it. I use it every day. However, I would like something a little brighter, with a switch, with as much runtime as possible. I would mostly use it for EDC, but would also take it on hiking trips and camping. Basically, if I was stranded and lost my pack, this would be in my pocket and I could navigate at night. If the below information doesn't allow for this, I'm all open to suggestions.
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
Up to $50.
3) Format:
I want a flashlight (hand held/self contained).
4) Size:
TINY - Every day carry (2-4 inches).
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
I don't know/I need more information on power sources.
I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
Less than 1 yard/meter (reading, other close work)
Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
5-20 yards/meters (check out a noise in the backyard)
3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
Very Important (Camping, Backpacking, Car Glove-box).
I want a tail mounted switch (found on the majority of today's high end lights).
A simple on-off with only one output level is fine for me.
or I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
14)Material/Finish/Coating
I don't care.
15) Water resistance
IPX7 (Waterproof to 1 meter/30min)
or IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
EDC
Up to $50.
3) Format:
4) Size:
6) Manufacturer:
I don't care.
EDC
