Taxman
I just received the rainbow alloy S41 from Banggood today. I have some unprotected 18350 cells on the way, but in the meantime I've got some 16340's. One is a Nitecore 600mAh and the other is a 700mAh Keeppower. Both are protected cells.
Something odd is happening with the Keeppower cell. When I put a fresh Keeppower 16340 in the light, I can't access turbo, it quickly flashes and goes dark. Try cycling back to turbo and the same thing happens. But as the cell gets used up while I use the light on other modes, I can then access turbo and it works. It's as if as the voltage of the light goes down with usage, the light
let's me access turbo mode. The cell in question shows 4.16 or so volts when I take it off the charger.
Whats is is going on?
