kj2
A year after Olight released the PL-1, they have released the new version, the PL-1 II.
KEY FEATURES:
More info about the PL-1 II, on the Olight website.
PL-1 thread; http://www.candlepowerforums.com/vb/showthread.php?405612-Olight-PL-1-Valkyrie-weapon-light
KEY FEATURES:
- Applicable on MIL-STD-1913 and Glock sized rails
- Uses a single CR123A battery delivering an output of 450 lumens and a beam distance of 106 meters
- Switch on/off silently. Push forward directly or hit the side of the switch to activate
- Heavy duty stainless steel lever making it easy and fast to attach and release
- Hardened glass coated with an anti-reflective coating on both sides allowing for 99% light transmission rate for maximum clarity
- IPX6 Waterproof
- Weapon Light x 1
- 1600mAh CR123A Battery x 1
- 1913 Rail Mount (for 1913 Rail) x 1
- T6/T8 Socket Head Wrench x 1
- Instruction Manual
Max Output (lumens) | 450 |
Low (lumens) | 450 |
Max Run Time (hours) | 1 hr |
Beam Distance | 106 m |
Peak Beam Intensity (candela units) | 2800 cd |
Water Resistance | IPX 6 |
Impact Resistance | 1 m |
Head Diameter | 1.22 in. |
Length | 3.07 in. |
Battery Type | CR123A |
Weight (oz) | 3.3700 |
