see level
Does anyone have a Derrelight x searcher? Just wondering if this is what the beam should look like.
Mine looks like this. Purple fringing around inner and outer corona. The hotspot is shaped like a box.
Is this the most intense hotspot you can make with this light?
The Xsearcher is/was offered in 2 different LED's. And the die projection size is smallest with the XPG2 version. From that photo posted with your last comment it appears to me to be an XML die size projection however that photo also appears to be inside of the focusable range. To show a precise focused die projection you would need to take the picture from apprx 8 to 10 mtrs at a min. I'd post my light showing the difference between the 2 LED dies and properly adjusted for a minimum focus range but I'm using a custom made Waiven collar so its focus is much more intense that your stock Xsearcher.
