I may get some push-back here but I firmly believe Surefire makes the best lights in the industry.
Maybe that used to be, but i think there are a few threads on here that discuss how they've gone a different direction. For instance, i think a lot of their new lights are not easily upgradable (ie P60 or Malkoff Format). Thats a big reason why i've bought a few of them (used mind you).
I have a need like all of us for more handheld lights in various places but I simply cannot afford several more Surefire lights.
Describe your "need" and where are these "various" places you want to store them. For instance, there are a lot of lights that are way brighter than the average P60 format can put out and a whole lot smaller. So much so that one place you may want to put a light is in your pocket. You can have a:
small thumb sized light (Olight S1, Zebralight SC32, Eagletac DC25C, etc.) which can run off of CR123 primaries,
palm length light (Eagletac DC25A, Zebralight SC52, etc.) which run off of AA batteries (or 14500 Litium Ion),
small 18650 lights (Zebralight SC63/63, Olight S2, Fenix PD35, Fenix PD32, BLF A6, Convoy S2+ in order of increasing size) which run off of an 18650 battery.
Midsized lights like your Surefire lights (Malkoff, Elzetta, Seraph, Solarforce, etc.) which run off of either 18650, 16650, or CR123s (X2)
The lithium Ion batteries are not recommended to store in high temperatures, like your car for instance, but all the other categories can be stored anywhere at the sacrifice of run time. You need to make the call where you want these strategically located lights and I think you'll find that a little bit of reading here may prompt you to try quite a few lights out like i did (it can get expensive). Have fun with that
Is there a manufacturer that you guys would consider "Next" in line as far as quality and durability to Surefire?
Thanks
SCD
This is subjective, after trying out a few lights, i like Zebralights the best for their size and ease of carry (I always EDC at least one Zebralight while trying to rotate through my collection). For the class light it appears you have, Elzetta and Malkoff would be even more durable than the Surefires although it would be close, however they
are more expensive.
Again, I suggest try out a few lights, especially the budget ones first, and see what suit your needs. Alternatively, find a specific need, then research what light is best for that need (This site is a wealth of info for reviews, recommendations, etc.). For instance, i have a need for a good waterproof light when i go out in my Kayaks ( or other boats when they are running
), this sent me to a brand called Armytek. Their QA is far from Surefire, but if you get a good one, they are incredibly durable. So now i have a Barracuda that i can use for spotting bouys and signalling boats that get too close if need be. That just one example, there are plenty of others. Good luck!
