Hi all,
I admit to be VERY confused regarding (new to me) the use of 18650 Cells. Long story short : I own two KLARUS Flashlights. An XT-11 and a XT2C both of which will support either a single 18650 or two CR123's. I also recently purchased a NITECORE D-4 Charger to recharge said 18650's. The Klarus Flashlights each came with a single PROTECTED 18650. Now.....I was told here by a member of CPF that my KLARUS lights would perform better using a UNPROTECTED 18650 Cells (I'm not sure I understand why). At any rate, I started researching and learned of the LG CHEM MJ1 UNPROTECTED 18650 Cells (which are said to be a very good and cost effective cells). So.....I contacted "Customer Service/Information Department" of this popular Battery maker of 18650's and posed the question regarding using "Protected vs. NON-protected" 18650's and I was told the following.....(in a Nut shell) :
No, using UN-protected Cells is NOT better than PROTECTED Cells. You CAN use UN-protected Cells IF your Flashlight will run Flat Top short cells.
The remainder of the Email from Customer Service included examples (in BOLD PRINT RED) of WARNINGS (from Battery makers) about using UNPROTECTED 18650 and also
a photograph of the new (soon to be released) CAUTION label being printed on future LG CHEM 18650 Batteries.
I'm a bit confused since this (on-line) store sells PROTECTED 18650's as well as the aforementioned LG CHEM MJ1 UNPROTECTED Cells.
Bottom line, can I SAFELY use UNPROTECTED 18650 Cells with my KLARUS Flashlight and, if so, (aside from cost) what is the advantage of using a UNPROTECTED Cell ?
Thanks so much for your thoughts/help/advice.
SixCats! in Maine
SixCats! in Maine
