Fenix Outfitters
Results 1 to 17 of 17
Thread: Quark 1xAA body & 14500
    Flashaholic* NutSAK's Avatar
    Jun 2006
    3rd stone from the sun
    Default Quark 1xAA body & 14500
    I've been using AW 14500 cells for years in my Quark Tactical AA and they work great, but my current ones are due for replacement. Due to AW cells being overpriced, IMO, I am trying to find another suitable brand of quality cell. However, it seems that the current batch of performers such as a protected Sanyo UR14500P are all too long for this application, at around 52.5-53mm. The AW cells are around 51mm and fit perfectly.
    Is there a good quality 14500 cell available that will work in the Quark AA body besides the AW? I am very good at keeping track of cell voltage, so I would be willing to use an unprotected button top cell if I could find one, but they all seem to be flat tops.
    I suppose I could also use a spacer between the body and tail to allow the longer ones work. If anyone has any good ideas for this, I would love to hear them.
    - Terry
    *Flashaholic* gunga's Avatar
    Nov 2006
    Vancouver, BC, Canada
    Default Re: Quark 1xAA body & 14500
    How about Efest or Windyfire imr 14500?
    Jun 2006
    Well, I'm looking for something that does well in testing. Those are mediocre. After looking through HKJ's tests, I think I'm going to try the Eagletac cells if I can find any without paying high shipping rates. Granted they would fit, but I really have no need for high-drain, low capactiy IMRs in this light.
    - Terry
    A&Q Moderator
    Woods Walker's Avatar
    Jun 2008
    New England woods.
    Quote Originally Posted by NutSAK View Post
    I have a Quark 1XCR123 which has an extra AA tube. I could test if a KeepPower protected 14500 will work if. I know you're more interested in unprotected but could check if yea like.
    The TK20. Yes it still rocks.
    Jun 2006
    I would appreciate it! I'm actually more interested in a protected cell that fits. I only mentioned unprotected because it should be easier to find one that fits without the protection PCB making it longer.
    - Terry
    A&Q Moderator
    Jun 2008
    New England woods.
    Am embarrassed to say I took the body out of my PSK, put it down in the house and now it's MIA. Looking for it right now!
    A&Q Moderator
    Jun 2008
    New England woods.
    Ok I found the 1xAA body (in the couch LOL!) for my QPLC. A KeepPower protected 14500 840 mAh battery does work (and dang bright) but the trail cap can't be totally screwed down. The tail is more than on however so wouldn't mind using it like this. The 2XCR123 Quark can take a 16650 without issue if my memory is correct.
    Jun 2006
    Thanks WW. My tailcap threads are all fully anodized, and lock out if slightly unscrewed, so that cell won't work for me. I also don't want to "squash" a cell and its protection PCB, so it needs a little "breathing room". Yes the 2xCR123 works with a 16650, but I'm not going to pocket that as EDC.
    Thanks for trying, and I'm glad you found your AA body.
    - Terry
    Flashaholic* Hondo's Avatar
    Oct 2005
    SE Michigan
    If it were me, I would do the same as I do on my 18650's and add a blob of solder to the positive end of an unprotected cell for a button. File flat after applying. You need to be confident, and prep the top of the cell perfect, with lite flux, so when you hit it with the iron, it tins out and bonds right away, don't want stay on long enough to heat the cell up to the point it might be damaged.
    I avoid magnets for this, as they can shift while assembling and cause a short.
    Jun 2006
    Thanks Hondo. I'm confident with my soldering skills, so I might try that.
    - Terry
    Jun 2006
    Sometimes the best solution to the problem is the simplest solution. This takes me back to the good 'ol days of fitting Nekomane bodies to L1Ts...
    Thanks for the suggestions Gunga, Woodswalker and Hondo!
    - Terry
    Unenlightened
    Aug 2019
    @NutSAK I too have an old Quark 1xAA and am currently looking for a 14500 battery. Have you been able to find a new 14500 to replace your AW cells that fit and perform well?
    Flashaholic* Jose Marin's Avatar
    Jan 2015
    St. Louis
    Vapcell has a 1000mah out. Im running one in my low volt xml2 tac head
    Granny shiftin not double clutchin like you should
    Wanted: quark 18650 body and malkoff wildcat v5 5000k mtg2 head
    peter yetman's Avatar
    Mar 2014
    North Norfolk UK
    Good spot Jose. My favourite battery shop has them over here but the picture shows a button top and the description is flat. Which are yours?
    P
    Peter's shopping list:- HDS / Oveready 170N Exec/LE and an Oveready V4 Nichia Drop In. Otherwise I'm content. Want want want, that's me.
    Jan 2015
    St. Louis
    Mine are flat with a small solder blob i put on myself. I realized after i ordred that you can custom order button tops or protection circuits by emailing vapcell
    For the past few years or so I've been using a Nitecore NL147 in my Quark AA Tactical... maybe not one of the best cells available but it fits perfectly & works well enough
    Flashaholic* Got Lumens?'s Avatar
    Mar 2011
    Champlain Valley
    Checkout KeepPower 14500 cells, they are very good and fit perfectly in the AA tube.
    JetBeam, Fenix, and EagleTac's fit also.
