HKJ
[size=+3]Eneloop lite AA 950mAh BK-3LCCE (Cyan)[/size]
Official specifications:
Maximum temperature raise at different discharge currents: 1A:+2,6°C, 2A:+3,4°C, 3A:+5,4°C, 5A:+8,7°C, 7A:+10,7°C, 10A:+11,0°C
The latest generation of of eneloop lite (2016).
The discharge curves has a very good match, but the capacity is low (As specifications says).
[size=+3]Conclusion[/size]
These batteries are for remote controls or wireless phones (DECT) and other equipment with low current consumption or very frequent charging. In neither case is high capacity required, but the low self discharge and the many charge cycles can be an advantage.
[size=+3]Notes and links[/size]
The batteries was supplied by Panasonic for a review.
How is the test done and how to read the charts
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
- Nominal voltage: 1.2V
- Minimum capacity: 950mAh
- Low self discharge: 70% capacity left after 5 years
- Cycle life: 3000 cycles.
