narmattaru
I`ve just seen new Imalent light with 16000 lumens in turbo stated.
If that is true or, at least, quite close it it, this flashlight may be quite interesting (depends on price of course)
"IMALENT DT70 is a versatile USB rechargeable LED tactical flashlight with multi-level output and OLED display. The OLED display can show battery voltage, output, charging, and has a flashing overheat warning, which makes it much easier and more simple to know the status of the flashlight. Utilizing the latest CREE XHP70 LED, its aluminum OP reflector helps distribute the beam more evenly, and can output up to 16,000 lumens. There are four output levels, with the tactical-switch button making it easy to operate.Supported by 4pcs of IMALENT 18650 Li-ion rechargeable batteries, its advanced temperature control module, low-voltage warning. and low-power protection, makes the DT70 the perfect flashlight for any demanding environment or scenario. "
