1500 Lm mode runs about 1-2 mins at ~ 20c (~68f) ambient temperature before stepping down and doesn't run much longer until -10c (14f) where it runs about 5 mins or so. That makes this light a bit questionable because 1500 Lm really lits indoors nicely and nearby surroundings, but can't do that long because of overheating. Basically this light could shine in cold weather like -30c (-22f) or so for decent 1500 Lm runtime (I'm going to test this when cold enough).
This is probably the only major negative thing for me. LEDs just aren't efficient enough to produce lots of light in compact light without heat issues. In my opinion, Zebralight should had chosen more cooling mass for longer 1500 Lm runtime. SC600Fd is quite small now and they aimed for a pocket light, but at least my pockets have room for a bigger light.
Maybe there is a bit hope and they just tweaked the thermal controlling tight so that the flashlight won't get too hot to hold with bare hands. They could then tell the code to loose that controlling, if you hold it with a glove or something. Zebralight could also release an attachment which would help to spread the heat for longer 1500 Lm runtime, but I don't know, if that kind of solution makes much difference.
