carlosdantez
- Joined
- Dec 17, 2016
- Messages
- 5
I own a surefire UBR invictus 1000 lumen flashlight as well as the UNR Commander 1000 lumen output as well. If your familiar with those type of rechargeable flashlights I'm sure you know that they are dual feed capable of using CR123's as well as a rechargeable battery stick. I have a feeling that the rechargeable battery is a 18650 type battery. Well after looking at the design one can modify the CR123 battery magazine and fit it with a 18650w battery. The reason I would want to modify the magazine to accept a standard 18650. The reason I would like to convert my magazine is because of the cost of disposable CR123 batterys. Second because when you use the 2 CR123 batterys in the flashlight it cuts the max lumens in half turning your 1000 lumen flashlight to a 500 lumens. The run time also gets cut in half which makes having to use 2 CR123's practically worthless. It's a nice feature but I would rather run it at full power with extra run time as well as save a few dollars on not having to buy CR123's. I have reason to believe that the reason SureFire discontinued the Invictus and Commander is because on can modify the battery magazine to except a 18650. I'm not rocket scientist but I have an idea that might make the SureFire rechargeable flashlights very desirable. The R1 Law man stick comes with the dual battery magazines which can give someone a reason to want to acquire one. Was wondering if anyone has done a conversion yet? I know it's easier said then done but one day I'm gonna make a prototype and but my idea into play just wanted to share my innovated idea
