What's the smallest light with a button switch? I am referring to a standard form factor, not something like a Tip. I love my E15 because of size but there is something about the one handed nature of the d25c.
Your title implicitly excludes high lumen lights.Yea those AAA are kind of weak lumen wise. It is weird to me there is so little support for clicky. It is pretty hard to use a twisty one handed?
I know that for me the smaller the light is the larger that even tiny differences can make then seem so it can be tough to get smaller in a meaningful or useful way sometimes too.Not sure why? I never asked for only AA/AAA only? Anyway, I actually have the new S1 Baton and overall like it, but for some reason the D25C just fits better in my pocket carrying it. Maybe because it is slimmer? It just feels harder to carry the Olight which was my concern with the new Foursevens Mark2. Then there is the Lumintop 007 but no clip for it.
But the Olight and D25C are almost exactly the same diameter to my eye?
And the D25C is longer too?
So I can't really grasp exactly what you are looking for now?
agreeThis kind of makes me think a longer/thinner light will "fit" better for me in my pocket.
D25C: Diameter 16-16.9mm
S1R: Diameter 20-21mm
If you're looking for a recommendation you may try posting in the recommend me a light section.
As for the tools, they run 1.2-1.5V cells, so they are at a natural disadvantage. They do provide a good EDC with easy to source batteries though, and the aluminum ones in particular make a nice lender light that people won't blind themselves on, and without the hazards of lithium rechargeables.
Otherwise if it is lumens you're actually looking for, step back up to the CR123 format for compactness of length such as the OLight mentioned above.
Agreed. Smallest light with a button, we're definitely talking AAA here. We're also not talking big output. As for the Tool. I have been using 10440 in mine for several months without issue. Maybe about 250 lumens from it. I don't want to damage the thing but they're so cheap these days that if the driver goes poof, I'll likely not cry much.
it is true that Tools do not support LiIon voltage officially..Do you have the current controlled one or PWM one? I carry a Copper one with the CC revision and I seem to recall it being said that the driver did not support the higher voltage.
