nervouswreckdiver
Has anyone found a suitable replacement switch that can be used in the Armytek Tactical lights(like a McClicky) as I have had 2 bad caps that don't consistently click on?
Have you contacted them about a warranty replacement?
Order from skylumen. They are called fs4 get the short one and switch only. i have one in my dp xhp35
You can order the same part from Mountain Electronics for $2.75 versus $14.00 on Skylumen
Thanks I tried the 20mm switch from MTN but it was too large, I'll try the 17mm, hopefully it will fit.
No it fit fine, i think i left one of the spacers out though. Yes you get a cheaper switch on mountain but skylumen's are modified for lower resistance and higher amperage. The xhp 35 armyteks draw around 6-7 amps, i actually got a few more lux after swapping the switchThanks for the tip. Did you have to modify the switch at all?
