lampeDépêche
- Joined
- May 15, 2012
- Messages
- 1,241
Got a question for you:
what determines the viewing angle of a 5mm LED?
Some shine a very narrow beam, some a very wide one--anywhere from 15 degrees up to 60 degrees and more.
What puzzles me is this: my first thought is that the epoxy lens shapes the beam. But the physical shape of the epoxy lens is the same for all of these different angles.
(Almost all of them--there are also so-called "straw hat" LEDS which are very wide angle, and have an obviously different epoxy lens. Let's ignore those for now, since the answer is easier.)
So we have two 5mm LEDs in front of us, with what look like identical epoxy lenses, and one of them is a 15 degree beam and the other is a 60 degree beam.
What makes the difference?
Is it the tiny reflective cavity around the tiny die?
Is it the position of the die in relation to the epoxy lens? (e.g., the die is set further down for the narrower angles, and closer to the top for the wide angles--like a zoomy!)
Is it the composition of the epoxy lens? (different refractive indices make for different lensing properties?)
Some other factor?
Related question: if I hand you a pair of bare 5mm LEDs, can you look at them with your bare eye and tell me which is the 15-degree and which is the 60-degree emitter?
All information gratefully accepted--thanks!
Some other factor?
