You're hung up on the 8 taps, forget about the 8 taps.
Programming Requirements:
-Ability to do a half-press/momentary
Programming Lucidrv2:
If you want to change general settings, the mode you are in when putting it into programming mode does NOT matter.
BUT if you want to change mode specific features such as brightness, strobe/solid, or adding/deleting a mode, it does matter.
Example: Change brightness on a desired mode.
All On states indicated below are half-press/momentary
1. Select the mode you wish to change and hold it on for 1+ seconds to select the mode for programming purposes
2. Now you cycle the power AT LEAST 8 times, don't try to do 8, just do a bunch. So you have the flashlight On, then Off-On-Off-On......Off-On.
Notice that the end of the sequence should be ON. This sequence is done fairly quickly >1/2 second each cycle
3. If you have completed the above sequence correctly, the light should flash a pattern indicating it is in programming mode
4. While the light is flashing you input your menu selection number via On cycles, such as for a the brightness menu,
(Brightness is menu 3) Off-On Off-On Off-On
5. The light will now ramp through the brightness levels starting from the lowest.
6. When the desired brightness is seen, select it via a power cycle Off-On
7. The steps are the same for the other options except that you'll get a different flashing sequence to indicate a different menu when selected.
8. IT IS VERY IMPORTANT THAT THE END OF EVERY CONFIGURATION ENDS ON AN ON-STATE. Otherwise the programming is incomplete and dropped.
