HighlanderNorth
I finally decided to use my Zebralight SC600 mk1 as my every day carry light, but after lugging around in my pockets for approx 2 months, I realized that a belt holster was necessary.
Its surprisingly tough to find ANY holster for ANY light in stores. I went to REI, ****'s Sporting Goods, and other stores, before finding one(read: "1") at Cabela's.
Its made by Nite Ize, and it was $8.99(or 535.80 rubles). My SC600 mk1 fits inside it perfectly, with less than 1mm sticking out on either end. It slides in tailcap 1st(down) and reflector up. When I need the light, I just push the tailcap upwards about 3/4" until the top half of the head emerges, then I pull it out by the head. Its a little tight for now, but it will quickly break in and loosen up a bit. Its not a problem though. It's made of thick nylon, with a protective nylon pad protecting the light's body. It's a nice holster than can be used for other lights of similar body thickness.
I also received my new Xtar VC4 charger, and received my Anker 2.4amp usb power source for the charger, both can be seen here. **I can't figure out a reliable and definite method of uploading photos, so I tried 2 methods.
https://goo.gl/photos/rxiwctB6cW2Sf2uu5
https://goo.gl/photos/B3yKmLaGkFsc7Tey7
https://goo.gl/photos/5XV8b1MKQtjnQYYg9
