Re: For the old timers here! Chameleon programing question and Lion cub
for future reference
LionHeart & LionCub Operating Instructions V2
Description The LionHeart is a single cell Lithium Ion based light that is Microprocessor controlled. All features are accessed via a single momentary action switch—there is no mechanical power switch. The momentary action switch and the Microprocessor firmware can put the electronic subsystem into a sleep mode where it consumes <30uA. For extended (year or more) periods of non-use it is recommended to remove the Lithium Ion cell and store it in a dry, cool place. Only a single Pila battery is recommended and approved for use with the LionHeart. The LionHeart can be user configured to operate in one of two different User Interfaces, UI-1 (with 5 discrete variable levels), or UI-0 (with 32 levels that are continuously variable).
*C A U T I O N ! — DO NOT DISASSEMBLE THE HEAD without reading this first – 1) The reflector only fits over the Luxeon star one way. If you look at the bottom of the reflector around the hole you will see two curved ridges. The two breaks between these ridges are where the leads of the Luxeon must fit into, BUT WAIT – there are also three legs, and the leg that aligns with the CENTER of one of those two curved ridges is the leg that MUST go into the cutout between the two soldered wire points on the Luxeon star. 2) Then place UCL lens on the reflector 3) Then screw bezel down over the lens/reflector, first making certain the lens o-ring is in place. 4) ANY deviation to the above procedure may result in mis-focusing or even permanent damage to your LionHeart. In fact if there is no need to open up the head, it is strongly suggested that you do not.
Commands: • CLICK – a short press and release (less than 0.3 seconds). • PRESS – a longer press and hold (greater than 0.3 seconds).
User Interfaces
UI-1 command UI-0
Latches the light ON at the level from which it was turned off, or at the level pre-selected under FORCE if FORCE is enabled.
CLICK from OFF
Latches the light ON at the level from which it was turned off, or at the chosen FORCE level if FORCE is enabled.
Turns the light ON at the dimmest level and cycles up through 5 distinct levels stopping at the brightest, or wherever the press is released. Repressing within 1.5 seconds reverses the scolling. Releasing for longer than 1.5 seconds locks in the setting—no more graduated adjustment is possible without first turning the light OFF.
PRESS from OFF
Turns the light ON momentarily (for as long as the PRESS is held) at the level it was previously turned OFF, or at the chosen Force level if Force is enabled. Releasing the switch turns the light OFF.
Turns the light OFF CLICK from ON
Turns the light OFF
Latches on to the brightest setting; an additional PRESS returns the light to its previous brightness, toggling back and forth with each subsequent PRESS.
PRESS from ON
Smoothly cycles through 32 levels, stopping at the brightest or dimmest, or wherever the switch is released. Initial adjustment is down, reversing direction each time the switch is re-pressed.
IN SHORT: In UI-1 three distinct levels are almost instantly available from OFF: Low (press, then release) Chosen Forced Level (click) High (click, then press)
CONFIGURING THE LION HEART
MENU SELECTION. Only one menu item can be changed per Menu Selection sequence. Changes are stored in nonvolatile memory and persist through battery changes until overridden by another menu change.
To access the Menu, begin with the light ON for at least 1 second. Then click the switch rapidly three times, no more than a seconds apart. The light will cycle off/on/off as you click, and then flash once and light up dim, indicating that Menu Mode is now active (but only for 2½ seconds, within which you must make your selection, otherwise the light defaults out of Menu Mode and you have to start all over).
Once in Menu mode, select as follows: 0 clicks (no selection): Times out to lockout. 1 click: Autosleep Enable/Disable. 2 clicks: User Interface Selection (U-0 or UI-1). 3 clicks: Force Mode Enable/Adjust/Disable. 4 clicks: Auto-lockout Enable/Disable. If more than 4 clicks are entered, the menu mode is exited, the LED flashes quickly 5 times to indicate a selection error and normal operation of the light resumes. Having entered Menu Mode with a triple CLICK (from ON ), waited for the single flash followed by dim light denoting readiness for input, then clicking 1 to 4 times according to the menu item to be modified, wait for the single flash. Then (within 2.5 sec.) continue as below.
LOCKOUT (one time only) — 0 clicks Lockout prevents accidental turn-on or unintended use. To manually enter one-time-only lockout, begin with the light on (for at least 1 second). Then click the switch rapidly (no more than a second apart) three times. The light will cycle off/on/off and then flash once (indicating Menu Mode) and then go dim for 2.5 seconds (awaiting menu selection, in this case none), then flash three times. The light is now in lockout mode and can only be turned on by three clicks spaced no more than a second apart. In short: turn the light off with a tripple-CLICK. To turn back on, triple-click or double-CLICK & press. AUTOSLEEP. 1 click after entering menu-mode If Autosleep is enabled, the timer will reset and start counting whenever the switch is clicked or pressed. When 15 minutes elapse without switch action, the Autosleep function starts dimming the light visibly each minute, then holding the dimmest level until turning itself off 60 minutes after the last switch action. A click or press prior to 60 minutes having elapsed will return the light to its original brightness level and restart the count-down. To enable AUTOSLEEP, enter MENU-mode by tripple-clicking (off-on-off). After the single flash CLICK once. Initially the LED will be dim to indicate Autosleep will be active (i.e. if you don't click, Autosleep will become active). A CLICK will brighten the LED to indicate Autosleep will be inactive. Each click will cycle from active to inactive. When you are happy with the choice, wait 2.5 seconds and the LED will flash once to indicate the selection has been made and the light
will then turn OFF. USER INTERFACE SELECTION. 2 clicks after entering menu-mode Enter MENU-mode by tripple-clicking (off-on-off). After the single flash CLICK twice. The LED will light up dim to indicate User Interface 0 will be active (i.e. if you don't click, UI-0 will become active). A click will light the LED up bright to indicate UI-1 will be active. Each click will cycle between UI-0 and UI-1. When you are happy with the choice wait and after 2.5 seconds the LED will flash once to indicate the selection has been made and the light will then turn off.
FORCE. 3 clicks after entering menu-mode
FORCE mode selects the level at which the light turns ON with a CLICK in UI-1, or momentary ON with a PRESS in UI-0. It is selected by 3 clicks from the power-on menu. The sequence will cycle through all 6 choices, starting with the LED dim to indicate that Force Level 1 (dimmest) will be active. Each click cycles to the next Force setting, the LED brightness matching the 5 operating levels of User Interface 1. When you are happy with the choice wait for 2.5 seconds—the LED flashes once aknowledging that the selection has been made.
The FORCE sequence is: • Level 1 – LED dim • Level 2 – LED med/low • Level 3 – LED medium • Level 4 – LED med/hi • Level 5 – LED brightest • Force Disabled (LED OFF)
If FORCE is disabled a CLICK will turn the light ON at the same level at which it was last turned OFF.
AUTO-LOCKOUT (permanent). 4 clicks after entering menu-mode Auto-lockout can be enabled so that each time the light is turned off it enters Lockout and requires 3 quick clicks (or 2 quick clicks and a press) to turn the light back on. First enter the menu with 3 CLICKS from ON. After the light flashes and dims to indicate Menu Mode, CLICK 4 times (less than 0.3 seconds apart) to enter Auto-Lockout. Initially the LED will be dim to indicate Auto-lockout will be active (i.e. if you don't click, Auto-lockout will become active). A click will brighten the LED to indicate Auto-lockout will be disabled. Each click will cycle from active (dim led) to inactive (brighter led). When you've made your choice, wait 2.5 seconds and the LED will flash once to indicate the selection has been made and the light will then turn OFF.
