•2017• POLL !MicroBluebear Acebeam K60 review! 5000lm 1 xhp70 Who here likes Acebeam!
Do you like Acebeam?
  • Total voters
    8
C7N3M T&T
MicroBlueBear Revival!
Today I've​ got a bit of an older one.
Shortly after the release of the xhp70 in late 2014, acebeam tossed one in there k60 about mid way through 2015! Though it's two years later, we haven't seen any updates for higher power LEDs.
Based on that I am going to say that this is still relevant and a very good flashlight in 2017. Acebeam did an absolutely phenomenal job with the k60 and it is still one of my favorite lights. The light comes in three different colors. I received the black one that I am reviewing.
The company:
Acebeam, formerly know as supbeam, and before that, microbluebear! MBB was never really a hit and wasn't considered high quality, nor was supbeam. When they changed their name to acebeam it was either live up to the name "ACE" or fail again and forever be know as failbeam!
Well... they didn't fail... Acebeam came in strong and brought (and is bringing) quality lights to the table of all kinds, at reasonable prices. Their number one is customer support (which I can personally speak from) and they have turned into one of the top manufacturers. Personally in my top 5!
Disclaimer- please excuse the dust, dirt, dings, and scufs on any of my flashlights in reviews. This one has been in use for the past couple of years. I like to give a tried and true review where I have used the light in my normal day to day life and work. I work in construction and as much as I love every flashlight… it is also a tool.
Unboxing:
The box that the Acebeam k60 comes in is made of a high quality cardboard. Much harder and stiffer than regular cardboard, with a plastic carrying handle.
Opening up the box you are greeted with a user manual and a warranty card.
Here are a couple pictures of the user manual
Removing those you can see the flashlight nicely nestled in the foam
The included accessories and replacement parts. Extra rear switch cover, heavy duty lanyard, and two spare O rings.
Nice cutout foam packaging to assure safe arrival
The flashlight in its included holster
Very nice flexible nylon holster
On the back there is a D ring for easy attachment. There is a Velcro belt loop for quick and easy attachment, or a more permanent stitched in belt loop where the warranty card is through
And finally On to the flashlight:
A picture of that gorgeous 7x7mm cree xhp70. AR coated lense and a deep orange peel reflector to smooth out the beam pattern and help with the spot to flood ratio
Another of it on in the lowest setting-moonlight-1lumen.
A very nice looking bezel that is substantially protruding to protect the glass.
Substantial thick flanged heatsinking to help dissipate the large amounts of heat that will be created from the led.
Built into the heatsinking are flat spots to stop the light from continuously rolling
Magnetic control ring to adjust the mode before or after the light is on.(UI..Couldn't be any simpler)
Additional positions on the mode ring include standby (which draws a very small amount of current so is not recommended to use as the official on off switch) and a multi frequency strobe.
The rear tactical clicky switch with momentary on. A cutout for easy access to the switch and many lanyard attachment points.
Very steady tail stand capability
Large but grippy diagonal knurling on the battery tube
And now Taking it apart:
The head separated from the body
The battery tube with battery's
Very nice retention on the springs and a very ridged cage
Acebeam's official high drain 20A 18650 battery's
The springs on both the front and rear are gold plated and very strong
With a dual spring in the rear
Oiled, square cut threads on both the tail cap and the head resulting in very smooth quite rotation
Everything disassembled
A couple shots showing size comparison to my hand/arm
Specifications(as per the manufacturers site):
LED: Cree XHP70 LED with a lifespan of 10+years of run time
Max 5000lumens output *using (4x 18650 power cell)
Output (select by magnetic ring):
***Level 1 : 1lm 1300hours;
***Level 2 : 50lm 60 hours;
***Level 3 : 700lm 8 hours;
***Level 4 : 1700lm 3 hours;
***Level 5 : 3400lm 1.5hours;
***Level 6 : 5000lm 1 hour;
***Standby : 65uA
***Strobe : 5000lm 3 hours;
Working voltage: 12V - 17V;
Max Runtime: 1300 hours;
Max beam distance: 704meters;
Peak beam intensity: 124100cd;
Impact resistant: 1.2 meters;
Waterproof : IPX-8 Standard (2meters);
Size: 206mm(length) x 88mm(head diameter)*50mm(tube diameter);
Weight: 570g(without batteries);
Aircraft grade aluminum body structure;
Premium type III hard anodized anti-abrasive finish.
ultra-clear tempered glass lens with anti-reflective coating.
momentary forward click tactical switch.
Strobe mode for tactical and emergency use.
Light orange peel reflector for both smoothing out the beam and max. beam distance.
tactical knurling for firm grip
streamlined body design
Mechanical reversed polarity protection design for battery carrier
Intelligent highly effcient circuit board design for max performance and long run time;
Specially designed for military,Law Enforcement, Self-defense, Hunting,Search&Rescue and outdoor activities.
Intelligent temperature controlled light output for user safety
Accessories include:
***1x user manual;
***1x lanyard;
***1x holster;
***2x Replacement O - ring and Tailcapgummi
Beam profile/beamshots:
As you can see the hotspot is a very large part of the beam. At the max of 700meters the hotspot is very big.
From low to high, gives an idea of the beam pattern. 2ft from wall
And the main attraction (at least what I head to first in every review) the beamshots.
Camera settings: ISO 100 Shutter speed 4seconds
100ft to evergreen tree
Moonlight 1lumen
Low 50lumens
Medium1 700lumens
Medium2 1700lumens
High 3400lumens
Turbo 5000lumens
200ft to treeline
Moonlight 1lumen
Low 50lumens
Medium1 700lumens
Medium2 1700lumens
High 3400lumens
Turbo 5000lumens
400ft to red trailer
Moonlight 1lumen
Low 50lumens
Medium1 700lumens
Medium2 1700lumens
High 3400lumens
Turbo 5000lumens
As you can see the k60 easily lights up a large spot at 400feet.
1100feet to farthest tree tops
Moonlight 1lumen
Low 50lumens
Medium1 700lumens
Medium2 1700lumens
High 3400lumens
Turbo 5000lumens
As you can see, a massive area is lit up.
Pros and Cons:
Pros
-Excellent beam
-Very usable hotspot
-Great runtimes
-Tons of sinking resulting in good runtimes on higher levels
-Uses rechargeable batteries
-Water resistant ipx8
-Drop resistance to 1.2m
-Well spaced usable modes
-5 year warranty
-Gourges
-Very bright!
Cons
-on cold evenings I find the lense gets a slight film of fog on the inside of the lense(nothing substantial, it would not affect output much)
-takes an extra second to get it out of the holster if you run it gets stuck down further(nice holster but I think I would prefer if it was a little stiffer
Conclusion:
I have absolutely loved my time so far with the Acebeam k60 and look forward to many more years with it and other acebeam products.
I can speak personally from their customer service as when I first received the product it had a faulty driver. I contacted my supplier and they contacted acebeam. Everything was solved very quickly and smoothly. I received the replacement part in a few short days and I was on my way.
This thing still blows me away everytime. Everyone I hand it to or turn it on in front of is like waaaht only 1 led? 5000lumens?
Bottom line I would say this is a must have.. oneday.. for everyone!
Thanks for reading, hope you enjoyed!
-C7N3M Tried and true reviews
richbuff
Prescott Az
I love Acebeam! I have and love the Acebeam K70vn and EC50vn and X65Vn! I love being first on a new topic.
I love not full quoting lengthy posts. I am kind of sort of eh on Poll topics.
I love review topics. I have thought very hard and very long about getting the K60, based on ven's killer beamshots and glowing recommendations, but not yet. Maybe soon!
Thank you for your informative review!
C7N3M T&T
Hey richbuff, no problem, thanks for reading and responding.
I love the ec50vn. Nice collection you have of vinh's acebeam products! 👍
ven
Manchester UK
Nice review, thanks for sharing thoughts and pics. I dont need to say i am a big fan of the k60, along with mr seery and a.marquardt .Certainly with a shaved dome! with near 200kcd and stunning beam............
k70vn
k60vn
x65vn 5000k
Yep a fan of acebeam:)
C7N3M T&T
k70vn
k60vn
x65vn 5000k
Thanks Ven!
Indeed it's hard not to be a fan of acebeam!
Thanks for the pics! X65vn is a real beast! Gorgeous tint on her!👍
harro
Northern Victoria, Australia
Love my K60 and K70, and while they may be eclipsed by another excellent manafacturers throw and flood options, they still give a darn good account of themselves in most all situations. As far as the K60 goes, for a SINGLE emitter hipo light, there aren't many other FACTORY STANDARD lights that come close.
Lighting for this shot was provided by Jetbeam DDR30GT and ceiling bounce.
Actually, come to think of it, i would not mind welcoming a T20 into the house either. A good thrower with a beautiful neutral to warm tint. Nice.
Rockjunkie15
I own both a K70 and an EC50gen II, they are very made lights that are easy to like.
C7N3M T&T
Harro,
You say there aren't many single emitter factory standard lights that come close to the k60, this is for sure!. I am unaware of any that surpass its sheer lumens. Anyone know of any?
proceed5
Love Acebeam yes !
I started with the purchase of my first Acebeam unit, the K70. Love it for its Range, Runtime and build. This is a fantastic light.
Feature loved most on Acebeams products = magnetic ring control, for it is easy to switch up / down and not have to cycle trough the entire cycle to select brightness levels.
Next, I bought another fantastic light, the K40M with my favourite MT-G2 emitter. This has a very nice Tint and a flood-thrower beam. IMO this nicely compliments my K70.
Other Acebeams =
H10 MT-G2 Neutral White 5k - a superb Headlamp, love the MT-G2 Tint especially in Neutral white 5k tint, Turbo press-n-hold can produce insane 2000 lumens from a Headlamp.
H20 XPL-HI Warm White 4k - a very nice Headlamp, Tint is warm ! big beam with only 1600cd
Love Acebeam indeed.
Look forward to their upcoming high quality launches.
C7N3M T&T
Love Acebeam yes !
Other Acebeams =
Proceed5, indeed the magnetic control rings are something all manufacturers should notice and copy! My favourite UI!
The k40m! Good choice! I love that mtg2. Thinking about the h20 in the near future myself[emoji106]
Newlumen
United States
Yes sir. I like acebeam. They are ahead of their game.. i have 7 acebeam lights, and one is on the way..
Pascal83550
Googletranslation
Hello, it's been several days that I read your forums, on tests the
Flashlight :)
And finally, this ACEBeam K60 lamp pleases me :)
And I want to know if it is battery: Samsung INR18650-35E 3450mAh - 10A, aresuitable for this
Flashlight where it is absolutely necessary totake AceBeam 20A batteries (ARC18650H-250A) :rolleyes:
I am looking for a torch, which has an important range (+ 500meters)
I do not know if this lamp is still relevant, or better since then?
I saw that there is torch which lights up more (but whose powerdrops quickly 5 minutes after the lighting)!
And moreover it lamp often lights up only at 300/350 meters!
If you know a better product for about the same price (- $ 200)?
Thanks in advance, for your advice :)
Pascal
