wjv
- Joined
- Aug 1, 2012
- Messages
- 962
I bought a Ray-O-Vac Indestructible and a MagLite (overview)
I was looking for a good "house, Kitchen drawer light" for my wife and kids to use. Currently all that is in the drawer is a Ozark trail 50 lumen (3xaaa) light. Not a bad light, but doesn't have much reach. And given that we live on an acre of land, I wanted something that they could use to illuminate the barn and the camper from the back porch, without having to leave the safety of the house. I wanted something with a long batter life, that preferably took 'D' cells, or maybe 'C' cells, and had a simple UI. So I bought 2 lights this weekend to try out.
1) Ray-O-Vac Indestructible
All of the Indestructibles in this family type like look like this:
Initially I wanted to buy the 2D cell version of this light (DIY2D-B) but when I saw it in the store, I realized that it was HUGE and HEAVY. There is no way my wife would have used it because of its size and weight. What I liked about the 2D version was the run times:
320L - 16h - 302m
75L - 160 - 148m
Next to it was the 3aa version (OT3AA-BC) which has the following specs:
330L - 3h - 271m
25L - 70h -
And at the back of that row was a older 3aa version (OT3AA-B) of the same light with the following specs:
180L - 7h - 313m
25L - 100h - 113m
Since I had ruled out the 'D' version of the light, I decided to go with the older version of the 'C' light because it had better run times, which I think is beneficial in a house light. Plus 180 lumens is sufficient for most general tasks.
Verdict:
I am quite happy with this light.
It has a fairly focused beam with some spill. The hot spot is OK, but not as well defined as you would find on something like my old (R5) Fenix TK15. A little blurry around the edges. But then I'm probably spoiled by all of the nicer lights I have!
The tint is pure white. No green, yellow or blue. Taking it outside at night it does really have some good throw, easily lighting up some objects that I know are 200 meters away.
The UI is very simple and a person would pick it up in seconds.
Off -> High -> Low -> Off
There is NO momentary capability.
Over all it is a nice house light. Especially if the users are not into flashlights and just need something easy to use.
I paid $29
2) MagLite LED 3C
This is 3 'C' cell light. I saw this in a local store so I picked it up without examining it very closely (big mistake).
At home I already have a 3C and a 3D MagLite, both which were converted with some el-cheepo LED drop-ins. Neither puts out much light, but they focus OK and the beams are very pure white.
So after removing the new 3C light from the package the first thing I noticed was that it was smaller than my old 3C light. A quick check showed it to be about two inches shorter. But the real change was the head. My two old MagLights have heads that are ~2-1/4 inch in diameter. The head on the new 3C light was only ~1-5/8 inch in diameter.
Second thing I noticed was that there was no side switch. It ends up it is a twisty! I have to take the blame for that since I really should have noticed this fact in the store. Still, it feels like buying an economy car and discovering that the seats have been replace with lawn chairs. I just didn't expect a larger light to not have a switch!
The specs on this light are:
173L - 18h - 309m
No low mode
Third thing was the beam. The tiny was more creamy/yellowish which may or may not be a bad thing based on your preference. But the hot spot was horrible. The hot spot on my old Maglites are not great , but this one was just a muddy blob. Changing the focus to flood I could only obtain a small amount of flood before the dark doughnut hole of death appeared in the center. Moving even further to the floody side caused many many rings to appear. Kinda looked like Saturn on my wall.
I took it outside and tried it while walking the dog. It does OK on a tight focus, but because of the tint the Ray-O-Vac Indestructible appeared to provide much better illumination. I think this light will be tossed it the trunk of my car as an emergency light as that's about all I would want to use it for. Plus I really hate the fact that it is a twisty, given its size.
I think that instead of buying any more MagLites, I will instead invest in some TerraLux drop in's, along with some new reflectors and lenses for my old MagLites. Those are built like tanks and you can see and feel that they are far better quality that the new MagLite I bought.
In the MagLite's defense I will say that I only paid $20 for the light so it is probably the economy version. But I have bought other lights for $20 that runs circles around this one. And for a few bucks more, I feel the Ray-O-Vac Indestructible is a far better choice for a house light, especially since it has a real switch; two easy to access levels; a pure white beam; a much better hot spot than the MagLite.
320L - 16h - 302m
75L - 160 - 148m
330L - 3h - 271m
25L - 70h -
180L - 7h - 313m
25L - 100h - 113m
Verdict:
I paid $29
2) MagLite LED 3C
173L - 18h - 309m
No low mode
