<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by 2d_edge:
How about comparing (photos) Action Light with Expedition 7, 14, and 19 as well as with LW4000, so we can have a good bearing of its lightbeam quality.
<HR></BLOCKQUOTE>
The beam quality/color is similar to that of the other multi-LED flashlights. The radiation pattern is similar, but the color may appear just a touch less bluer because it doesn't overdrive its LEDs whatsoever, not even on the 'high' setting.
You should also be aware that I strongly suspect this model uses Nichia 4,000mcd LEDs - which at the time it was made were the best available. So it isn't nearly as bright as today's model might be.
It might not be a fair comparision when tested alongside brand new Trek 7, 1400, and 1900 models because they use 9,000mcd LEDs and at least one of the three models also overdrives them by a substantial degree.
May I suggest battery runtime test and comparing lightbeams (Action Light, Expedition (TREK) 7, 14 & 19, LW4000) at distance of 10, 20, 40 feet from target subject to show size of lightbeam, lightbeam throw, and color defining quality.
<HR></BLOCKQUOTE>
The sample came with 1 lithium sulfer dioxide battery. They aren't available locally (not to mention they cost $20 + S&H when ordered on the net), plus I need to leave some power in it for the next guy down the line. So I will have to estimate battery power & runtime after taking electrical measurements.
For beam throw, I can do 10 feet (indoors only), but not 20 or 40. This is a smaller-than-average 1BR apt in the central core of downtown Seattle, and there's no place I can go out at night dark enough to set this test up without getting a gun to the temple or a knife in the belly.
So any comparision will necessarily be limited to a relatively short 10-15 foot range indoors. Maybe when Brock gets it, he will find Green Bay to be less of a high-crime area than downtown Seattle, and can do the longer-range testing.
I don't think my camera is sensitive enough to pick up the beams beyond 10-15 feet anyway, but Brock's probably is.
Also, I no longer have the LW4000, as it was a loaner that has since been returned.
I don't think Brock has his anymore either.
I (we) can do the Trek models though.
Sorry to disappoint you, but you're asking considerably more than I am capable of doing.
To properly do all of these tests as you describe, the reviewer would need to be wealthy (to be able to burn off $70 worth of batteries) and live on a farm where city lights aren't an issue.
