i want to use a variable voltage transformer to run some 12 volt led strips. All I see on the 'variable output ' is an adjustment slot. Is there any device I can use to read the amount of voltage. Excuse me if my terminology is incorrect, my knowledge on the subject is iffy at best.
TIA
Mike Lynch
- Output Type: Single
- is_customized: Yes
- Output Frequency: 50-60Hz
- Output Current: 10A
- Output Power: 101 - 200W
- Output Voltage: DC18V
- Model Number: S-180-18
- Input Voltage: AC110V/220V
- Input Voltage:: AC100+/-15%V/220+/-15%V
- Input Frequency:: 47-63Hz
- Under voltage protect:: 115-150%
- Input voltage recovery:: Failback
- Input Overvoltage Protection: 115-150%
- Input overvoltage recovery: Failback
- output voltage: DC18V
- output Power: 180W
- Size: 19.8*9.8*4.2CM
- Function: Indoor Power Supply
TIA
Mike Lynch
