Re: Fenix E35UE
I purchased a Fenix E35UEa couple years ago. Then a couple months ago the switch became stuck and the light wouldn't turn on. I called Fenix and they just sent me a new head that turned out to be the newer model. They didn't ask questions or ask for the broken head. So, I decided I had nothing to lose and proceeded to tear the rubber cover off the old head to see if I could fix it. As it turns out the plastic piece that goes into the switch was just stuck, and it works just fine now.
Anyway, to my point. Fenix "upgraded" the light to include a designated SOS/ strobe switch and gave it 5 brightness levels, including a 1000 lm turbo mode that stays on instead of having to hold it down. The new brightness settings were a very welcome upgrade. I won't discuss the SOS/ strobe. So anyway, I noticed last night that the new head's reflector is more shallow than the original, and decided to test them to see if that translated into a floodier beam.
I found that the older head has a much smoother spill and a more defined hotspot. The hotspot is also larger and more even. The new head has a much more rough, uneven spill and the hotspot is smaller and seemingly not as bright. The new head, however, has a considerably wider, floodier beam.
So to conclude, I felt it was worth noting these facts as Fenix had supposedly "upgraded" the E35. They definitely did improve upon the brightness settings on the new model, however, it suffers when it comes to the quality of the beam, not hugely but noticeably.
