Manker T01, 900 lumens on 14500
I do love my 14500 cells. But they are not AA cells. FYI, AA cells are
only 1.2V-1.95V, counting all valid chemistries I am aware of that can be considered proper AA, which include:
- NiCd 1.2V (1.45V, Nickel Cadmium, "NiCad")
- NiMH 1.2V (1.56V, Nickel Metal Hydride)
- ZnCl 1.5V (Zinc Carbon, "Duty," "Heavy Duty," "Super Heavy Duty," "Ultra Heavy Duty," primary)
- ZnMnO2 1.5V (1.65V, "Alkaline," primary)
- LiFeS2 1.85V (L91, Lithium Iron-Disulfide, primary)
- NiZn 1.85V (1.95V)
- NiOx 1.7V (Nickel Oxyhydroxide, primary)
- LiPo 1.5V (Kentli, Lithium Ion Polymer)
14500 cells
are always much higher voltages, and include:
- Li4Ti5O12 2.4V (NMC, 2.8V, Lithium Titanate)
- LiMnO2 3V (CR14505, 3.3V, primary)
- LiSOCl2 3.6V (LTC, Lithium Thionyl Chloride, primary)
- LiFePO4 3.2V (LFE, 3.7V, Lithium Iron Phosphate)
- LiMn2O4, or LiMn, 3.7V (IMR, 4.2V, Lithium Manganese Oxide)
- LiCoO2, or LiCo, 3.6V (ICR, 4.2V, Lithium Cobalt Oxide)
- LiNiMnCoO2 3.6V (NMC, 4.2V, Lithium Nickel Manganese Cobalt Oxide)
- LiNiCoAlO2 3.6V (NCA, 4.2V, Lithium Nickel Cobalt Aluminum Oxide)
Bolding the "safer" or most stable cell chemistries from both groups, only by accepted convention (nothing is really "safe!") as reported by CPF members
Anyhoo, IMO, the brightest flashlight on AA are the various Zebralight SC5 models. Even though they step down after 3 minutes, though the user can immediately restore the turbo brightness after step down for at least several iterations while the AA voltage lasts. Before step down they hold a constant brightness, depending on the exact model, 500lm-530lm, besting many 14500 flashlights and the Klarus mentioned by OP, which has an exaggerated brightness that doesn't last more than a few seconds, if that, as stated above.
