Nope....
There's only a handful of LED manufacturers to begin with: Lumiled, CREE, Seoul Semiconductor, Osram, Nichia
Lumileds Rebel is the latest they have but can't compete on the white end of things, they seem to have created a remarkable variety for color. What lumileds are making that's great are COB, or LED arrays that are useful for architectural lightning, but very difficult to collimate for flashlight use.
Seoul Semiconductor.... disappeared after making the P-series LEDs [P3, P4, P7, P9]. Right now the only widespread availability from SSC is a warm white Z-Power, but even then its been known that SSC uses CREE dies.
Osram makes some pretty good LEDs, but at very specialized wavelengths [like IR or UV]
Nichia makes wonderful LEDs for color rendition, but its significantly dimmer than cool white LEDs and is considered something of a specialty or custom order.
Mainstream is still CREE.
In terms of flashlights for Osram and Nichia, sure. But if you ever look at any commercial LED light bulb for normal household fixtures, it'll most likely be Nichia or Osram. I haven't found much in terms of Cree household lighting.
What does Surefire use in their small lights?
What about the LED used in Streamlight? I only see it referenced as "C4". Who makes that?
C4 is purely a marketing term that stands for 'Whatever LED we want to use.'
The odds of a bulb having an OSRAM LED is virtually 0 with the exception of very high CRI bulbs which are a very small part of the market. OSRAM is just not remotely competitive this market.
Even Nichia would be rare in the bulb space .... Again expensive. Most bulbs today will be using Chinese brand LEDs which is just fine. They color is good, efficiency good and life acceptable.
Nichia does very well in fixtures where long life and better color control is required not to mention efficiency especially at higher drive currents to keep LED cost down. The tier 2 and 3 are not that far behind but don't have the reliability both of the product and supply chain.
I'll give a slightly different answer.Fenix, Olight, Thrunite, Nitecore etc eveyone uses Cree LEDs.
Are these the best LEDs right now, like Intel has the best CPUs?
Well, that explains that. It seems people would be less likely to buy Streamlight if they have no idea what LED is in there. I was clueless about LEDs when I bought my first high output flashlight (Streamlight ST-88040). I don't think I would buy another light not knowing what LED it uses.
