<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by videocal:
As the owner of 3 Eternalights,
I have to give that mickey mouse battery compartment a huge "thumbs down" for not having spring loaded battery contacts-(like every other light
does have
-major aggravation!<HR></BLOCKQUOTE>
I just opened up an Ergo Marine (the yellow eternaLight) and it has springs & polarity markings inside. It was also equipped with a set of Energize E2 Photo Lithium cells, so it is ready to go over the side of your boat (and remain afloat) as soon as you open the pack.
I had a bit of a struggle getting the batteries in right, but the act of placing the two flashlight halves together sets things right. Compressed foam inserts on the lid help keep the batteries in place and prevent any rattling.
However, I also opened up my Classic (the one in the picture above) and some of the interior elements are hauntingly Turbospyder-esque. There are no polarity markings or true coil springs, but at least they used spring brass leaves for the contacts instead of the malleable copper weatherstripping the Turbospyder uses.
So it would still be superior to the Turbospyder in terms of durability and overall mechanical reliability. This model isn't waterproof, so it won't be going in the tub along with some of the others. There are instructions provided for reviving a waterlogged Classic.
The instructions (for all models of eternaLight) also warn that installing the batteries backwards will damage (or destroy) the flashlight, so for models where polarity markings are not present you should either mark the polarity inside the light yourself or watch which way the original batteries were put in when you change them.
I suspect the Rave'n has a similar interior configuration as the Classic, but it did survive a brief exposure to a rainstorm with no leaks.
However since it isn't sealed 'round with a ring, like the Classic it too must stay out of sinks, tubs and toilets if you want it to last.
I'm currently in the process of testing five models of eternaLight and some initial results should be appearing on my site within the next day or so. The existing eternaLight page will be overwritten, since all models have been improved since I last tested.
