TigerhawkT3
This light is anything but simple, and it doesn't seem to exist anywhere online. I still have the manual, so here it is:
http://tigerhawkt3.com/lf2/
The PDF is the complete manual. The INDD (InDesign CS5) is the source for the PDF. The PNGs are the source for the flowchart images. The .gliffy files (Gliffy) are the source for the PNGs.
Sorry about the image quality, but recreating the flowcharts was enough work in an actual flowchart tool like Gliffy - I wasn't about to do it in InDesign.
Just for redundancy, here's the text of it:
Introduction
Thanks for your purchase of LF2 flashlight. A new designed 2-stage switch mechanism and MCU control circuit are included. LF2 supports 4 operation modes and 5 useful functions. You can access any operation mode by few times of switching action, didn't need to pass through the useless mode. You can adjust intensity from very dim to brightest easily by using user adjusted mode. All the intensity of operation modes can be adjusted and stored settings into EEPROM in MCU (Standard, Strobe and SOS mode only). Strobe mode can be adjusted into many kinds of strobe format by setting ON and OFF periods to meet what you want further. You will find that LF2 is powerful and useful to meet any application.
Battery Replacement
Definition
Operation modes exchange and description
Function description and operation
Introduction
Battery Replacement
- Remove the head cap by completely unscrewing it counter-clockwise.
- Install AAA battery with the positive (+) end up, toward the head cap.
- Replace the head cap and turn clockwise to secure.
Definition
- Shut down position: Turn head cap clockwise or tube body anti-clockwise to secure.
- Position 1 (abbreviation: P1): 1/4 turn from shut down position to loosen.
- Position 2 (abbreviation: P2): More 1/4 turn from Position 1 to loosen.
- Switch cycle (appreviation: SW):
- From P1 to P2 and back to P1, all the periods must less than 1 second.
- From P2 to P1 and back to P2, all the periods must less than 1 second.
- Standard mode: In any operation mode SW x 1 will change to standard mode. There are two positions indicated two different intensity output (P1 & P2). Both of the intensity can be set by using programming function.
- User adjusted mode: In any operation mode SW x 2 will change to user adjusted mode. In user adjusted mode, P1 position means fixed intensity and P2 means a changing intensity position. In P2 position will increase or decrease intensity. Inc or Dec are depend on the setting flag which is Inc initially and can be toggle to Dec by SW x 2.
- Strobe mode: In any operation mode SW x 3 will change to strobe mode. There are two positions indicated two different intensity and strobe format output (P1 & P2). Intensity and strobe format can be set by using programming function.
- SOS mode: In any operation mode SW x 4 will change to SOS mode. There are two positions indicated two different intensity output (P1 & P2). Both of the intensity can be set by using programming function.
- Battery voltage report: In any operation mode SW x 5 will go into battery voltage report function. On the beginning turn off output and measure the voltage of battery after that begin to flash indicated voltage in format – integer no. – blank 2 seconds – decimal no. When finish showing will back previous operation mode.
- Programming function: In any operation mode SW x 6 will go into programming function, there are 6 parameter needing to set (standard mode P1 - standard mode P2 - strobe mode P1 - strobe mode P2 - SOS mode P1 - SOS mode P2 in serials).
- Standard mode P1: Setting the intensity of standard mode P1 position, method is similar to user adjusted mode. SW x 2 toggle Inc/Dec (default is Inc), in P2 position Inc or Dec intensity and in P1 position fix the intensity. After setting the intensity what you want SW x 3 will save the setting and go next setting.
- Standard mode P2: Setting the intensity of standard mode P2 position, method is the same as (1).
- Strobe mode P1: Setting intensity and strobe format of strobe mode P1 position.
- In the beginning is set intensity, method is similar to (1).
- *SW x 4 will toggle intensity or strobe format setting.
- In strobe format setting SW x 1 toggle ON period or OFF period. SW x 2 toggle Inc/Dec period (default is Inc). P1 means fix period position and P2 means changing period position (Inc or Dec).
- After set the intensity and strobe format SW x 3 will save it and go next.
- Strobe mode P2: Setting intensity and strobe format of strobe mode P2 position. Method is the same as (3).
- SOS mode P1: Setting intensity and strobe format of strobe mode P2 position. Method is the same as (1).
- SOS mode P2: Setting intensity of SOS mode P2 position. Method is the same as (1). SW x 3 will save the setting and go back to previous operation mode.
- Demo function: In any operation mode SW x 7 will go into demo function. Demo function will disable SW detection and show all operation modes once. After finish showming modes will back to previous operation mode or you can turn OFF and ON to back to previous mode.
- Rechargeable battery over discharge protect function: In any operation mode SW x 8 will go into this function. SW x 2 toggle ON/OFF, ON enable rechargeable battery over discharge protect function and indicated flash by 2 Hz frequency, OFF disable this function and indicated flash by 1 Hz frequency. SW x 3 save setting and back to previous operation mode.
- Reset function: In any operation mode SW x 10 will go into reset function, and will clear data in EEPROM to original setting. After that will back to standard mode.
