[ QUOTE ]
harebawl said:
Hey justintoxicated,
What was the final circut...? I want to build a 2 - 4 Lux headlight for my KTM 2 stroke. I know how I am goint to mount them, I just need to know what I need to do to drive them? I just want something bright to fill in the gaps when the rpms are down....or are these dimming down on you at low rpms? I was planning on using a battery pack, but I won't if I don't need to.
[/ QUOTE ]
They dim a bit when im not on the throttle
Here is a little video. about 1.4 megs
Rev Video
No problem for me, Im always on the throttle, or at least cruzin. I don't care much if they are not bright when I am stopped.
I'm also going to toss 2 Lux V's in my stock headlights (and point them off to the sides, But I may have to toggle them depending on wether or not my stator can handle it in combo with the underlighting. It is an aftermarket 200 watt stator and my handlebar mounted headlights are pulling 150 watts, so I think ill be ok, but it will be close.
I like the affect, since im usualy draging up the hill at night, now you can "see" feel, hear and smell the RPMs as I dump the clutch in second gear /ubbthreads/images/graemlins/smile.gif
