Gransee
Merri and I just got back in Phoenix from the SS tonight. I am catching up with the CPF threads and notice that there still intermittant problems with the AAA. I am going to inquire on this tomorrow starting with a review of warranty returns then onto indepth testing of products on the shelf and finally on to a fix. I was talking to Henry about this last night and we both agree that we will probably have to use a different chip in the AAA. The manufacturer of the DC/DC chip changed where it was manufactured and something has changed with how the chip works. It appears to be in spec but no longer works reliably in our circuit. When we originally detected this we tested the light and found it sometimes would not turn on. We added another capacitor to the circuit and this fixed all the test units. But we are still getting complaints and I don't think these are old stock. Our current test consists of 50 turn on/off cycles with the light being placed in the freezer and then in hot water to stress the circuit. The test I am going to run tomorrow will consist of 20 production units hot/cold and 50 cycles. If they all pass 50 cycles, we will increase it to 100 cycles (we use gloves to keep our fingerprints attached). I expect to find a problem and it will probably be with the chip. I have asked Henry to prepare to put our other engineering projects on hold and redesign the circuit in the AAA/AA with another chip. The head will likely need to be changed as well to make room for the larger chip. If there is a problem with the current design, I will freeze or cancel all orders for it and sell the stock as "seconds". We will either refund or replace previous models that exhibit this defect.
I will keep you posted.
Peter
Peter
