Well, it works. Sort of. You can mount the titanium clip from dark sucks onto the light and carry it in the V70, but you have to orient the light in such a way that the clip does not make contact with the retention device. This means putting the clip more or less in the channel that was designed for a lanyard. However, the problem is that the light will not be perfectly vertical inside the holster. It has good retention, but the light is tilted at an angle.
This is also the sort of clip that requires an additional O-ring in the neck of the light to take up slack between the clip and the tail cap. It works best with a clicky tail cap. Rotary caps move around too much to have a consistent amount of pressure on the O-ring, pocket clip assembly.
Edit: Got the photos working.
