Atnoonidrinktea
- Joined
- Jul 23, 2017
- Messages
- 3
Hi everyone,
I purchased this SC600w mkIII HI in January 2017 and then again in July 2017. The distributor (Nkon) was so kind to replace the lamp up to 4 times but it looks like I will send it back again for a refund.
This is the problem that I get:
Sometimes when I switch on the lamp (full power) after a second, the lamp switches itself completely off. When I click again, nothing happens (lamp dead). Only after the second click, the lamp behaves normally.
This happened in 2-5% cases, when switching on. If you plan to use the light in EDC/security sensitive applications it may take away your confidence. It bothers me anyway for a light bearing this price tag.
This occurred with all 4 samples I got in my hands. Batteries are fully charged LG INR18650-MJ1 3500mAh - 10A, I tried switching batteries (of the same type) but with no success. The lamp was held still in my hands, no shocks involved. One sample had a spring in the tail cap instead of pogo pins but still the same behavior.
The distributor told me they got a few instances of this complaint, and they were thinking that this was only a problem with the first production batches.
But I see this problem recurring and would like to know:
- Is it a common failure to the whole SC600mkIII series?
- Is there an easy fix?
- Is there any other observations or useful comments on the reliability of this light?
I was thinking that maybe CPF can shed some light on this matter, and maybe it would be good to share above information, to avoid other users to suffer in silence.
By the way, I never had this problem with the SC62 (lost due to poor clip) and SC63 (with new black clip from SC5, much better)
Thanks in advance for your advice and comments
