scviper576
Acebeam ec35 1200lm vs Streamlight Protac hl 750lm. I say they are the same the seller said the acebeam is brighter.
protac hl
ec35.
Best sense I've read all day.just use the one that meets your needs and don't worry about the numbers printed on the box.
That is how I measure perceived relative luminosity. Small white room, such as a bathroom, works well. Turn on the lower powered light first, then the next most powerful light.Do a ceiling bounce test as a quick check. Position the lights as low as possible and keep the beams unobstructed. That acebeam light has been reviewed on here and its output measured by the way.
I do ceiling bounce comparisons like this:
If you're looking directly at the hotspots during your comparison, you're not measuring lumens, you're comparing lux (throw).
