witness
Can anyone explain the difference between the Zebralight SC600w Mk III Neutral White High Intensity and non High Intensity versions?
Yes, the xhp35 HI has a flat dome(flat layer across the quad die), kind of like a de-dome LED without the tint shift that is normally associated with it. They seem to sit between a domed LED and a custom de-dome(dome removed to increase the throw). Ones i have are very nice in colour temp and tint, the 4500k and 5000k especially so. The mkIII is no thrower in either guise, but if throw is your forte then the HI should be the proffered choice of the two with a more concentrated hot spot.
