FNinjaP90
- Joined
- Jan 8, 2003
- Messages
- 888
I am finally done putting 30 5mm LED's in parallel into my TI83 silver calculator powered by 4 1.2nimh aaa's. Sorry but my digital camera is with my dad. I'll have pics friday.
When I was planning the project, one of you guys said that I needed a 40ohm resistor. With that installed, the blue and white LED's barely lit up. That is what is recommended for 1 LED, but with 30, it changed drastically. Tried 22ohm, same thing. Finally searched for an LED calculator, said I needed a 1omh resistor. I thought that the 16ga wiring gave enough resistance, so with no resistor, WOW! This thing lit up!
The bad thing is that when the LED's are running, the battery doesn't supply enough voltage to power the calculator. So.. might as well try to find some way to sneak some more cells in there.
I put 6 LED's directly in the front of the calculator. Do 5mm LED's really have 1 lumen each? I swear that the 6 make at least like 20 when I compare it to my e2e's mn03.
