hi all.
i have a tl-3. i never payed much attention to it for some reason. i have had it for a while and never used it accept when i first got it for maybe 10 minutes. anyways, i decided to play with it yesterday. first off the thing is not any brighter than an e2e. it is rated at 200 lumens and realisticly should put out over a hundred. i just wanted to be sure it is the batteries before i order more since i am out and don't really need any at the moment. could it also be the bulb or something? the other thing is the batteries are too loose in the tube. my normal fix would be to tape around the batteries. but i don't like this fix since battery replacements never occur at convienient times. what could i make a sleeve out of that will fit the tube. there is about a 1/12th. inch too much space in the tube. otherwise i like the style of this light.
thank you,
nitebrite.
thank you,
nitebrite.
