I have been playing with some super brights to tide me over till I get some LS's.
this is what has come out so far.
the LED arrays on both is a drop in module I have been working on.
the green is a 2D I got for cheap that the switch was drilled out (thanks turbodog). I have 3 C's in it powering 17 LEDs (I was able to route out the switch module to allow for the extra room I needed for the 3rd C cell.)I just need to get a sleave to limit the slapping around.I assume a 1" ID PVC pipe would be the trick?
I replaced the switch with a 10 amp rocker switch that works really well (this will be great when I put the LS aray in it (I want to try 3 5watters). I used the factory M@G rubber cap to cover the switch and maintain a bit of water tightness. I took it off for the Picture.
the Black one is a 3D Cell with 9 LED's. it runs forever and is a bit more over driven than the Green due to a few less LEDS.
I may put a 1 ohm resistor in both to tone the current down a bit but I have been using my dim Incan Batts in them so the voltage is staying safe.
Beam Shots Will follow soon.
