georges80
I had a request to assemble a flexiled into case.
First pic shows the unit about to be closed up. I attached the uFlex driver with some double sided foam. The jack on the side allows DC to be provided externally and disconnects the batteries during that time. DC can be from a wall wart or automotive 12V.
The next picture shows the back of the case - with the 4AA nimhs installed. A lid then slides and clicks in - nice case. uFlex is set to one of the dim levels to not blind the camera.
And the last picture shows it all finished and turned on.
With 4 nimhs the light should run for at least 5hours at full output and of course a LOT longer if dimmed down a level or two. In nightlight mode it should run for a few hundred hours.
george.
george.
