I have a light (which I'm building from scratch) that uses 19 amber LEDs tucked neatly into a 1.2" circular pattern.
I chose these particular LEDs bacause they throw the most tightly collimated spot of any I have seen. They are claimed to have an 8 degree beam, but in fact they cast an image of the LED die, square with a round central hole and two leads on opposite sides. That, combined with the fact that they are quite bright, should give them a longer throw than any normal 5mm LED light. I have arranged all the diodes with the negative lead towards the outside of the pattern, so all the square beams blend into a bright round spot.
Here is the datasheet on the LEDs I'm using: 5mm AlInGaP LED datasheet
My problem is that these LEDs are very finicky about drive voltage. They do not reach 20mA or anything like full brightness until 2.2x volts, and by the time I deliver a whole 2.40 volts, they are pulling around 50 mA each and dimming/reddening from the heat.
They really, really want just 2.3V, no more or less.
If I use 2 NiMH cells with a low ohm limiting resistor, either the initial voltage will fry them or the flat voltage portion of the discharge will be undesirably dim. If I use alkalines with a resistor it's just hopeless.
What I really need is a current limiter in the 500mA range, but all the LED-specific ones I know of are intended to send between 3 and 4V.
Is there a current-limiting board available that will send 500mA at 2.3V reliably? What choices do I have other than wasting batteries using a converter board WITH a limiting resistor? ('Cause that just don't set right with me.) /ubbthreads/images/graemlins/thinking.gif
Chalo Colina
Chalo Colina
