gunfighter
CFP,
This is not a brand-specific complaint. I'm open to any and all ideas.
In short, I've been religiously carrying a 1x18650 EDC for about three years. First is was an EagleTac PX30 variant, and now it is a Nitecore P12GT. I use my EDC every day at my job, and there are unfortunately times it does get dropped or bumped. My current EDC has worn exterior anodizing in many places, and there are significant amounts of pocket lint on the outside surfaces.
In the same case with both lights, after about six months of use the light becomes unreliable. In other words, it doesn't immediately work right out of my pocket. I either have to fiddle with the tail-cap switch, or disassemble and reassemble the light.
This is a big problem for me, as I also rely on this light for emergency and/or defensive situations.
I'm curious to know if I'm just doing something wrong. Is there some sort of regular maintenance I'm missing? Should I be proactively replacing parts? Is this a ground corrosion problem with the anodizing? Or maybe the protection circuit in the battery (always Panasonic brands) is on the fritz due to my body heat?
Any insight would be appreciated. I would like to find an EDC I can trust and I don't have to keep replacing on an annual basis.
Thank you
Thank you
