D
**DONOTDELETE**
Guest
Photon 2 and CMG Infinity w/ L91 AA lithium battery 12hr/10-minute interval run.
"Photon 2 and CMG Infinity 12hr run"
If link above doesn't work try this and click for full size image (1245x1788 226kb):
http://albums.photopoint.com/j/ViewPhoto?u=443720&a=12971438&p=48741575&f=0
At the start Photon 2's brightness overwhelms Infinity until after the first hour where they're just equal in brightness, and on the second hour Photon 2 is dimmer while Infinity continues with the same brightness up to the 12th hour.
I'll have to do this again because I made the mistake of positioning lightbeams too close to each other.
Maybe using a small object target will be good because it will show better the length of useable brightness in the 12 hr run.
Suggestions and critics are welcome.
edit1 05-19-01: having hard time with ubb link code
edit2 05-09-01: replaced image
- verge -
- verge -
