jnathan
Hi friends, I looked around to see if there was a thread that touched on this question but couldn't find one. Please forgive me if my searching abilities are truly that poor...
About a year ago I purchased one of the ED20Ts with 3400MaH 18650 from Amazon and managed to lose it about 9 months later. Recently I purchased another for the incredibly low price of $14.95 from Walmart's online store, but this second light seems to behave a little differently than the first... or at least I think it does.
If I turn the light on, select the lowest output mode, turn the light off and then use the momentary on feature: when I switch the light back on using the power switch, it comes on at the highest output mode. That is, the last mode memory doesn't seem to work under these circumstances.
If I turn the light on, select the lowest output mode, turn the light off and then use the strobe feature - after turning off the strobe: when I switch the light on using the power switch it, comes on at the lowest output mode. That is, the last mode memory seems to work under these circumstances.
I wrote to Lumintop, but I'm afraid that due to a mixture of language barriers and poorly explaining myself, I didn't get a clear answer from them.
I was hoping someone else with one of these lights could let me know whether their light operates as mine does.
Thanks,
-Jeff
Thanks,
-Jeff
