HKJ
[size=+3]TrustFire IMR26650 3400mAh (Red-gold)[/size]
Official specifications:
This 26650 cell is fairly low capacity, but high current.
The discharge curves looks good, it can deliver up to 20A with nearly constant capacity.
[size=+3]Conclusion[/size]
This looks like a fairly good battery for high current application, but capacity is fairly low by todays standard.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Battery Capacity (Mfg Rated): 3400 mAh
- Battery Chemistry: Li-Ion
- Battery Feature: Rechargeable
- Battery Form Factor: 26650
- Battery Maximum Voltage: 4.2 V
- Battery Minimum Voltage: 2.85 V
- Battery Rated Voltage: 3.7 V
- Anode material: LiNiCOMnO2-C
- Discharge Rate: 20C
- Maximum discharge current: 68A
- 300-500 times rechargeable
