The new Surefire EDCL-2t has got me thinking about my perfect edc light. I have the following lights, but none of them is quite right. A Vital Gear 1x cr123 body and Lumens Factory 3 mode head has excellent output and throw, but it's too small and you can't lock it in a mode or pre-select high or low. My Surefire 6p has great output with my homemade 2 mode drop in, but it's too big to carry and, again, you can't pre-select hi or low. The Solar force 2xAA is a great size, you can pre-select hi or low with a head twist, and the pocket clip is positioned just where I like it, but the high is less than 200 lumens. They all take rechargeable batteries. Darn, I can't post my picture of these three lights.
Anyway, I want to put together my perfect edc light and here is what I am trying to accomplish:
1. Rechargeable 16650 or two 16340 batteries.
2. 5 to 5.5 inches long and 1 inch at maximum diameter.
3. Bezel down carry with very little tailcap sticking out of my pocket.
4. At least 500 lumens and good throw on high.
5. Low in the 5 to 20 lumens range.
6. Select hi or low from tail cap or head twist. For example, Elzetta or Malkoff systems. OR the two stage Surefire gas pedal switch available on some E series lights.
The Surefire EDCL-2t looks promising, but it isn't made for rechargeable batteries. Any suggestions on parts to Lego my perfect light? Lumens Factory has a single mode, E series head with XPL HI bulb that could work, but it needs a way to provide the low mode. The Malkoff MDC 16650 is the perfect size, carry setup, battery, and output but it is lmh. If I could get it with the selector ring it would be perfect.
If you have ideas for a light I could assemble that fits these requirements, I would love to hear them.
