Russtopher
- Joined
- Nov 25, 2017
- Messages
- 3
Are COB (chip on board) flashlights a new technology? I just purchased a couple of small ones. They appear to be high drain devices too.
Thanks
Russ
Thanks
Russ
Yes I think so. The problem with LED's are making them alike enough so that some do not hog all the electricity while others are dim. COBs use a bigger area making them run cooler thus more efficiently. You may have gotten an older regulator like a resistor that is wasting electricity. The disadvantage is it is harder to focus a big area so at the moment these are flood lights.
Thanks
Russ
Go get the nebo big larry and lil larry, you'll love it.
Are the new xhp35, xhp50, and xhp70 leds COBs?
I have several cheap COB flashlights including small keychain lights.
I have 3AAA COB lights with separate LED optic beam, an 18650 LED/COB light, a 2x2032 coin cell COB keychain light, and a 1AAA keychain COB light.
The ones I use the most are the 3AAA and 1AAA COB lights due to their small size with pretty big flood.
COB lights are good for flooding but do suffer from not having all white coverage near the edges it shifts to yellowish color and if you rotate the light you can tell that there is areas that are brighter and darker not an even fading flood output.
I also have a cheap 3AAA COB headlamp I got for about $3 locally. IMO COB is the "new" fluorescent of lighting, that is it looks to be the "go to" for area lighting that fluorescent battery lights were to the 80s etc.
Lynx, I'm curious what brand/model your 3AAA Cob light is as well as your 1AAA Cob light.
Thanks in advance!
No brand names..... Chinese Ebay finds.
The 3AAA COB light comes in red, black, and blue and is plastic and about $2. It has a magnet on the end and a clicky switch with two modes: Beam/Flood/Off.
The 1AAA COB light comes in several colors and usually has a cheap caribiner attached to it. It costs around $2 also. It has 3 modes: High/Low/Strobe.
