My surefire e1b MV sucked through its first battery in what seemed like about 20 minutes of run time. It went out quickly and had very little to no taper. I realize the ANSI ratings are down to 10% of max output, which is bad enough, but mine didn't even come close to the poor ANSI rating. Why?
I think it has to do with the fact that I run my lights in relatively short bursts. Most lights are programmed to draw heavily at start up to meet manufacturer "lumens output" claims but drop down considerably in a short period of time to increase "battery life" claims and reduce heat. Sure you can get an hour+ (ANSI) out of a battery if you run the light constantly but I usually only run the light for short periods of time. Because I'm almost always using initial battery draw and initial draw is very high (amperage wise), my battery life is tanking severely.
20 minutes on a light rated at 1.25 hours.
Anyone else experience the same thing? Why can't manufacturers rate lumens and battery life honestly? Maybe ANSI should change their standard. Comments and observations welcome.
