LightObsession
- Joined
- Nov 12, 2004
- Messages
- 1,385
I discovered this light when perusing the Tank007 website yesterday while examining the WF01 a bit more. It's way bigger than I'd carry, but combines two features that I've been wanting in 1 light, though a much smaller one, maybe 1AA - focusing and adjustable angle head. And this angle adjustment is actually 100 degrees, rather than the more common 90 degrees.
It's also rechargeable and has a magnetic tail.
Product Description
◆KC70 is a lamp with 90 degrees rotation function ,zoom focusing, tail magnetic, direct charge and other practical features etc. As a high-power flashlight, very suitable for duty, maintenance, inspection and other workplace
◆ Using Cree XM-L2 LED, lifespan can reach 100,000 hours
◆ It can be free to rotate within the 90° range of activities, can freely adjust the irradiation angle
◆ It's metal clip for easy holding in the pockets or belts and other clamping parts can release your hands.
◆ Tail with strong magnetic to facilitate the absorption of iron surfaces and release the hands
◆ With zoom focusing function, meet the needs of focus beam and flood beam
◆ Direct charge design, with a dedicated USB charging cable can be charged directly through the computer, mobile power bank and other 5V output device charging
◆ Front switch, easy to operate
TECHNICAL PARAMETERS:
(1) LED SPECIFICATIONS: Brand & Model: USA Cree XM-L2 LED
Lifespan: above 100,000 hours
Max Brightness: 600 lumens Throw Beam: 300 m
(2) CIRCUIT SPECIFICATIONS: Input Voltage: 2.8-4.2V
Output Level: 3 modes (High-Med-Strobe)
Chip characteristics: Regulated current for constant output
(3) BATTERY SPECIFICATIONS: Power Source: 1*22430Li-ion battery
Burn Time: high light- 2hours; low light-10 hours
(4) PHYSICAL SPECIFICATIONS:
Size(cm): 13.7(length)* 2.7 (body diameter) * 3.5(head diameter)
Weight(g): 180 (excluding batteries)
Switch: Button switch in the head (Press and hold the button switch for 1s)
Material: made of durable aircraft-grade aluminum T6061
Reflector: High temperature vacuum coated aluminum mirror reflector Lens: tempering optical lens
Treatment: premium Type III hard-anodized anti-abrasive finish
Waterproof: IPX-7 Anti dropping height: 1.2 m Color: black
ACCESSORIES:
Accessories: 1* 22430 Li-ion battery, charging cable, pocket clip, O-ring
Optional accessories : 5V charging head (USB interface), car charger head (USB interface)
Product Description
ACCESSORIES:
