HKJ
[size=+3]Leise AA 2700mAh (White-blue)[/size]
Official specifications:
Maximum temperature raise at different discharge currents: 1A:+2,6°C, 2A:+4,5°C, 3A:+7,5°C, 5A:+14,3°C, 7A:+21,3°C, 10A:+27,9°C
High capacity AA battery directly from China
Curves looks like NiMH usual do. The cells are a bit lower than rated capacity (2700mAh often is that). Output voltage is slightly lower than the best batteries.
[size=+3]Conclusion[/size]
It is not top cells, but they look fairly good.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
- Name: Leise aa s 2700mAh NiMH Rechargeable Batterie
- Capacity: 2700mAh
- Voltage:1.2V
- Chemistry: Ni-MH (Nickel Metal Hydride)
- Rechargeable Times: Up to 1000 times
- Color: blue&white
- Size: 50*15*15mm (single)
