Hi! Let me first say I've sent Olight a message about this since the flashlight is under warranty, but I thought I'd post here just to see if anyone else has encountered a problem.
I bought an S2R Baton recently from OlightStore, and I've used it mostly indoors. Recently, I went to turn the light on and it was dead. At first I thought maybe I'd left it on and killed the battery, but checking with a meter showed the battery open circuit voltage was exactly what I'd expect. But when I reinstalled the battery in the light, it was still dead. Not on lockout, I checked that. Nothing I could do with the button would make the light come on.
Yes, I am sure I took the sticker off the battery. The light had been working fine.
I tried dropping it on the charging dock. No change. It acted as if it wasn't making contact with the charger, either.
After taking off the tailcap and putting it back on about two more times, the light suddenly started working. It worked great for about a week and three charge cycles, then the same thing happened again.
This is one weird symptom. It's almost as if something in the tailcap isn't making good contact, but everything seems clean and bright.
The special battery they use ... a LiCo 18650 with both + and - contacts at the tail, about 1 mm apart ... that's kind of scary. What if something like a bit of metal shaving from the threads got into that 1mm gap and shorted it? Sounds like a recipe for kaboom.
Anyone had anything similar happen to an S2R?
